Wish you could take your desktop workstation on the road with you? The HP ZBook 17 offers HP's ultimate in power plus portability with a 43,9 cm (17.3") diagonal screen, massive scalability and configurability, and all the latest power-packed features.
Carry it with confidence
Push the boundaries of performance without pushing the boundaries of portability. HP's biggest and most powerful mobile workstation just got 25% thinner and 11% lighter than the previous generation, with a stunning magnesium aluminum facelift.
Create your ideal workstation
Enjoy Intel® Xeon® processor options, up to 64 GB ECC memory, dual 1 TB HP Z Turbo Drive G2, for up to 4 TB of total storage, dual Thunderbolt™ , and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It’s reliable, designed to pass MIL-STD 810G testing, and endure 120K hours of testing in HP's Total Test Process.
Product Description | HP ZBook 17 G3 Mobile Workstation - 17.3" - Intel Core i7 - 6700HQ - vPro - 8 GB RAM - 1 TB HDD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache | Memory | 8 GB DDR4 (2 x 4 GB) | Storage | 1 TB HDD / 7200 rpm | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | AMD FirePro W6150M / Intel HD Graphics 530 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 6-cell - up to 15.75 hours | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Colour | Space Silver | Dimensions (WxDxH) | 42 cm x 28 cm x 3 cm | Weight | 3 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM236 Express |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 1 TB HDD SATA 6Gb/s / 7200 rpm |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Full HD ultra wide-viewing angle (UWVA) anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | AMD FirePro W6150M / Intel HD Graphics 530 |
Video System Features | Shader Model 5.0, AMD Enduro technology |
Camera | Yes - 720p |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | CX7501 |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 96 Wh |
Run Time | Up to 15.75 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging) |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, Password Manager, Windows Defender, One Step Logon, HP Registration, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Credential Manager, HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Mobile Connect Pro, HP Image Assistant (free download) |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Features | HP 3D DriveGuard, HP DuraKeys, HP SpareKey, One-Step Logon, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication, HP Sure Start with Dynamic Protection |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+ |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
