Wish you could take your desktop workstation on the road with you? The HP ZBook 17 offers HP's ultimate in power plus portability with a 43,9 cm (17.3") diagonal screen, massive scalability and configurability, and all the latest power-packed features.
Carry it with confidence
Push the boundaries of performance without pushing the boundaries of portability. HP's biggest and most powerful mobile workstation just got 25% thinner and 11% lighter than the previous generation, with a stunning magnesium aluminum facelift.
Create your ideal workstation
Enjoy Intel Xeon processor options, up to 64 GB ECC memory, dual 1 TB HP Z Turbo Drive G2 for up to 4 TB of total storage, dual Thunderbolt 3, and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours of testing in HP's Total Test Process.
Product Description | HP ZBook 17 G3 Mobile Workstation - 17.3" - Intel Core i7 - 6820HQ - 16 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English | Processor | Intel Core i7 (6th Gen) - 6820HQ / 2.7 GHz, up to 3.6 GHz / 8 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD - HP Z Turbo Drive G2 | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro M3000M / Intel HD Graphics 530 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 6-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, smart card reader | Colour | Space Silver | Dimensions (WxDxH) | 42 cm x 28 cm x 3 cm | Weight | 3 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6820HQ / 2.7 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM236 Express |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - HP Z Turbo Drive G2 |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare, High Bit Rate 2 (HBR2) |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro M3000M / Intel HD Graphics 530 |
Video System Features | NVIDIA Optimus, Shader Model 5.0 |
Camera | Yes - 1280 x 720 |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | CX7501 |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 96 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , Dock , LAN , 4 x USB 3.0 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, HP Spare Key, Password Manager, Microsoft Internet Explorer 10, HP Peak Power Manager (free download), HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Trust Circles Standard, Privacy Manager (free download), HP Disk Sanitizer, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Software Setup, HP Client Security Manager, HP 3D DriveGuard |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | Intel Active Management Technology (iAMT), HP DuraFinish, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, EAL 4+, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
