Get the ultimate blend of design and performance in the next generation HP ZBook Studio. Speed through your work and bring your ideas to life on HP's brightest 4K laptop.
Product Description | HP ZBook Studio G5 Mobile Workstation - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 512 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache | Memory | 16 GB DDR4 (1 x 16 GB) | Storage | 512 GB SSD - NVMe, TLC | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P1000 / Intel UHD Graphics 630 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, ClickPad | Keyboard | UK | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0 | Battery | 4-cell | Features | Ambient light sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 36 cm x 25.4 cm x 1.89 cm | Weight | 2.05 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0, Intel Optane Memory Supported |
Memory | |
RAM | 16 GB (1 x 16 GB) |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC) |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 400 cd/m² |
Features | Full HD eDP anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro P1000 / Intel UHD Graphics 630 |
Sound | Stereo speakers |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Wireless-AC 9560 |
Compliant Standards | IEEE 802.1x, IEEE 802.11i |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 64 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 150 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB-C 3.0 , HDMI , Headphone/microphone combo jack |
Memory Card Reader | Yes (SDHC Card, SDXC Card, SDXC UHS-II Card) |
Miscellaneous | |
Integrated Options | Ambient light sensor |
Features | Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.05 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
