Limitless human imagination—that’s the inspiration for the HUAWEI Mate 20 Pro. The breakthroughs in technology will blur the lines between what you can dream and what you can do.
Natural Masterpiece
A forged masterpiece of 3D glass with smooth curves and seams that dissolve into the design. A streamlined symphony in the palm of your hand.
Balance in Art
Like all works of art, HUAWEI Mate 20 Pro’s lines and features are symmetrically in harmony. A slim design makes the phone size a pleasure to look at and touch.
The World is Your Playground
Life is about exploring. Take your HUAWEI Mate 20 Pro for fun to the beach or through the rain. The IP68 rated water and dust resistance means no worry of taking spills, splashes, and dunks.
World’s 1st 7nm Mobile AI Chipset
The industry-leading 7nm process technology of Kirin 980 generates direct performance upgrade of speed improvement and power efficiency.
Ultimate Speed
HUAWEI Mate 20 Pro is the World’s first 1.4 Gbps LTE Cat.21 smartphone which supports up to 1733 Mbps WiFi download speeds. Enjoy rapid, seamless connectivity anytime, anywhere.
Precise GPS
By leveraging L1&L5 dual frequency simultaneously, HUAWEI Mate 20 Pro allows you to always find the destination with great accuracy even in city centres surrounded by skyscrapers or highway interchanges.
Massive Capacity
Enduring power is always the symbol of the Mate series. A larger 4200 mAh battery with smarter AI power management fuels your daily work and entertainment needs.
New Leica Triple Camera
The new Leica Triple Camera powered by AI reveals life’s drama, texture, colour and beauty in every photograph that will take your breath away.
Designed for different scenarios, the 40 MP main RGB lens captures great details in everyday photos, while the 8 MP telephoto lens will focus on your distant shots and the whole new 20 MP Leica Ultra Wide Angle Lens is perfect for the landscape photos and macro shots.
Get Closer
Capture details and surprises you couldn’t before. The Leica Ultra Wide Angle Lens takes extreme close-up shots from 2.5 cm. Discover the world from a new perspective.
AI-Painting Photography
recognising more than 1500 scenarios and 25 categories, the upgraded AI-powered photography now can segment different objects and scenes in one photo. Colours, brightness and contrast are adjusted automatically and precisely, just like fine-painting a photo, with perfect balance.
Capture the Night
Powered by advanced AI Image Stabilisation, the Night mode will shoot blur-free and focused handheld photos in low-light. It also balances high-contrast scenes to present incredible images in every setting.
3D Face Unlock
A leap in accuracy and security. Thanks to the 3D Depth Sensing Camera projecting over 30000 points, HUAWEI Mate 20 Pro recognises you easily to unlock your phone swiftly. Your face ID can also be used to securely access a private screen containing locked APPs and personal data.
In-screen Fingerprint
With the ergonomic design and Dynamic Pressure Sensing technology, you just need to raise your finger and touch the screen, your phone will get unlocked securely and instantly.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Huawei Mate 20 Pro - Twilight - 4G smartphone - 128 GB - GSM | Product Type | 4G smartphone | Display | OLED display - 3120 x 1440 pixels - 6.39" - 538 ppi | Processor | Hisilicon Kirin 980 2.6 GHz (8-core) - 64-bit | Memory | RAM 6 GB / 128 GB | Supported Memory Card | NM card slot - up to 256 GB | Operating System | Android 9.0 Pie with HUAWEI Emotion UI 9.0 | Main Camera | 40 Megapixel - wide-angle lens - f/1.8 - focus: automatic | Second Camera | 20 Megapixel - ultra wide-angle lens - f/2.2 | Third Camera | 8 Megapixel - telephoto lens - f/2.4 | Front Camera | 24 Megapixel f/2.0 - automatic | Service Provider | Not specified | SIM Card | Single-SIM - nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth | Security Devices | Face recognition, fingerprint reader | Messaging Services | SMS, MMS | Connectors | USB-C | Wireless Charging Standards | Qi | Protection | Dustproof, splashproof, waterproof | Colour | Twilight | Dimensions (WxDxH) | 72.3 mm x 8.6 mm x 157.8 mm | Weight | 189 g | Specific Absorption Rate (SAR) | 0.4 W/kg (head) , 0.96 W/kg (body) , 2.98 W/kg (limb) | SAR Category (Belgium) | C | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 72.3 mm |
Depth | 8.6 mm |
Height | 157.8 mm |
Weight | 189 g |
Body Colour | Twilight |
SAR Value | 0.96 W/kg (body), 0.4 W/kg (head), 2.98 W/kg (limb) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Operating System | Android 9.0 Pie |
User Interface | HUAWEI Emotion UI 9.0 |
Navigation | GPS, A-GPS, GLONASS, BeiDou, Galileo, QZSS |
SIM Card Type | Nano SIM |
SIM Card Qty | Single-SIM |
Input Device | Multi-touch |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE Advanced, VoLTE, FDD-LTE, TDD-LTE, VoWiFi |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19 |
3G UMTS Frequency | 2100, 1900, 1700, 850, 800, 900, 800 |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 6, Band 7, Band 8, Band 9, Band 12, Band 17, Band 18, Band 19, Band 20, Band 26, Band 28, Band 32, Band 34, Band 38, Band 39, Band 40 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 850, FDD 2600, FDD 900, FDD 1800, FDD 700a, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor, gravity sensor, infrared (IR) sensor, laser sensor, colour temperature sensor |
Security Technology | 3D Face unlock |
Additional Features | Wi-Fi Miracast, Neural Network Processing Unit |
Media Player | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, OGG, MIDI, 3GA, MP4 |
Supported Digital Video Standards | MPEG-4, 3GP |
Processor | |
Type | Hisilicon Kirin 980 |
Clock Speed | 2.6 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | 6 GB |
Internal Memory Capacity | 128 GB |
Supported Flash Memory Cards | NM card - up to 256 GB |
Front Camera | |
Sensor Resolution | 24 Megapixel |
Lens Aperture | F/2.0 |
Focus Adjustment | Automatic |
Features | 3D Depth Sensing Camera |
Main Camera | |
Sensor Resolution | 40 Megapixel |
Lens Type | Wide-angle lens |
Lens Aperture | F/1.8 |
Special Effects | HDR |
Face Detection | Face detection, smile detection |
Light Source | Dual LED flash |
Features | Phase Detect Auto-Focus (PDAF), Continuous Auto Focus (CAF), Depth Auto Focus, Leica Triple Camera, AI Image Stabilisation, 3D Live Emoji |
Second Camera | |
Sensor Resolution | 20 Megapixel |
Lens Type | Ultra wide-angle lens |
Lens Aperture | F/2.2 |
Third Camera | |
Sensor Resolution | 8 Megapixel |
Lens Type | Telephoto lens |
Lens Aperture | F/2.4 |
Display | |
Type | OLED display |
Diagonal Size | 6.39" |
Display Resolution | 3120 x 1440 pixels |
Display Format | 2K+ |
Pixel Density | 538 ppi |
Colour Depth | 16.7 million colours |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C |
Battery | |
Capacity | 4200 mAh |
Fast Charging Technology | HUAWEI SuperCharge technology |
Wireless Charging | Yes |
Miscellaneous | |
Compliant Standards | IP68 |
Included Accessories | Power adapter, SIM card removal tool, USB-C to 3.5 jack adapter, USB-C cable, USB-C headphones |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
