Visuals with vision
See the world in crisp and vivid colour with the HUAWEI MediaPad T3 8-inch IPS HD Display. This high resolution display will bring your watching experience to next level while providing for comfort, for your grip, and for your eyes. The blue-light filter and low-light display modes make sure that you don’t tire your eyes.
Strength of design in an elegant package
Strong things can come in slim packages. HUAWEI MediaPad T3 delivers power and smooth usability while being only 7.95 mm thick and weighing in at just 350 grams. Housed in this elegant case is everything you need to enjoy a truly modern online experience.
Sleek, Solid Style
Made from a solid piece of sleek anodised aluminum, the feeling of this device exudes sleek strength and refined style. The sleek design and the raw power of this device are perfectly captured in the tastefully polished metallic finish.
Joy that lasts
HUAWEI MediaPad T3 delivers long-lasting enjoyment, even with heavy use. The 4800 mAh (TPY) battery keeps the lights on for longer, giving you an unrushed, uninterrupted experience.
Take your family along
Smart app access and content control allows you to let others use your device in a way that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | HUAWEI MediaPad T3 - tablet - Android 7.0 (Nougat) - 16 GB - 8" | Product Type | Tablet | Operating System | Android 7.0 (Nougat) | Display | 8" IPS - 1280 x 800 | Processor | Qualcomm MSM8917 (Quad-Core) | Processor Clock Speed | 1.4 GHz | Storage | 16 GB | RAM | 2 GB | Supported Flash Memory Cards | microSD, microSDHC, microSDXC | Wireless Connectivity | 802.11a/b/g/n, Bluetooth 4.1 | Rear Camera | 5 Megapixel | Front Camera | 2 Megapixel | Navigation System | GPS/GLONASS/BeiDou | Features | USB host | Dimensions (WxDxH) | 12.47 cm x 0.8 cm x 21.11 cm | Weight | 350 g | Colour | Grey | Localisation | United Kingdom | Environmental Standards | ENERGY STAR Qualified |
General | |
Display | |
Type | 8" IPS |
Resolution | 1280 x 800 |
Features | Motion Eye Care |
Processor | |
Processor | Qualcomm MSM8917 |
Number of Cores | Quad-Core |
Memory | |
Storage | 16 GB |
RAM | 2 GB |
Max Supported Capacity | 128 GB |
Communications | |
Security Protocols & Features | WEP, WPA, WPA2, Wi-Fi Direct |
Bluetooth Profiles | Hands-Free Profile (HFP), Object Push Profile (OPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP) |
Rear Camera | |
Sensor Resolution | 5 Megapixel |
Still Image Resolutions | 1600 x 1200, 2592 x 1944 |
Front Camera | |
Sensor Resolution | 2 Megapixel |
Navigation System | |
Receiver | GPS/GLONASS/BeiDou |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, OGG, M4A, MID |
Supported Digital Video Standards | DivX, AVI, MKV, MOV, 3GP, TS, FLV, 3G2, M4V, WEBM, MP4 |
Audio | Microphone, speaker |
Software | |
Preloaded Software | Huawei Emotion UI 5.1 |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD |
Interfaces | 1 x headset , 1 x Micro-USB |
USB Host | Yes |
Battery | |
Capacity | 4800 mAh |
Miscellaneous | |
Colour | Grey |
Case Material | Metal |
Sensors | Gravity sensor |
Features | Super Wide Sound (SWS) 3.0 |
Included Accessories | Power adapter |
Cables Included | USB cable |
Dimensions & Weight | |
Width | 12.47 cm |
Depth | 0.8 cm |
Height | 21.11 cm |
Weight | 350 g |
Sustainability Information | |
ENERGY STAR Certified | Yes |
