iiyama ProLite TF1015MC-B2 10.1" 1280x800 25ms VGA HDMI...
iiyama ProLite TF1015MC-B2 10.1" 1280x800 25ms VGA HDMI DisplayPort Touch LED Monitor
£276.08
13 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Touch through-glass
  • Touch technology - capacitive
  • Open frame brackets
  • Foam seal
  • Anti-fingerprint coating
  • Diagonal Size: 10.1in
  • Max Resolution: 1280 x 800
  • Response Time: 25ms
  • Interfaces: DisplayPort, VGA (HD-15), HDMI
Product codes
The ProLite TF1015MC (10.1 inch) uses PCAP touch technology and is built into an eye catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF1015MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description iiyama ProLite TF1015MC-B2 - LED monitor - 10.1"
Device Type LED-backlit LCD monitor - 10.1" - touchscreen
Energy Class Class E
Power Consumption (On mode) 8.1 W
Features Touch-screen
Panel Type VA
Aspect Ratio 16:10
Native Resolution 720p 1280 x 800 at 60 Hz
Pixel Pitch 0.1695 mm
Brightness 500 cd/m²
Contrast Ratio 1300:1
Response Time 25 ms
Input Connectors HDMI, VGA, DisplayPort
Colour Black
Dimensions (WxDxH) 26.05 cm x 3.95 cm x 18.35 cm
Weight 1.4 kg
Compliant Standards Plug and Play, DDC-2B, CB, cULus, REACH, TUV Bauart, IP65, SVHC, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£276.08
