The ProLite TF3215MC-B1 (31.5 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape and portrait orientation ensures flexible mounting possibilities in almost any installation. The TF3215MC-B1 is the ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description | iiyama ProLite TF3215MC-B1 - LED monitor - Full HD (1080p) - 32" | Device Type | LED-backlit LCD monitor - 32" - touchscreen | Energy Class | Class F | Power Consumption (On mode) | 27 W | Features | Touch-screen | Panel Type | A-MVA3 | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.3637 mm | Brightness | 500 cd/m² | Contrast Ratio | 3000:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 73.95 cm x 6.1 cm x 43.4 cm | Weight | 10.3 kg | Compliant Standards | Plug and Play, DDC-2B, CB, CU, REACH SvHC, IP65 front | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 32" |
Brightness w/touchscreen | 460 cd/m² |
Vertical Refresh Rate | 47 - 63 Hz |
Horizontal Refresh Rate | 30 - 68 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | Cable management cover, HDCP, anti-glare, fanless cooling, landscape mode, portrait mode, 24/7 operating mode, TouchPro Pro-F Projected Capacitive (PCAP) technology, kiosk mode |
Colour | Black |
Weight | 10.3 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
VESA Mounting Interface | 200 x 200 mm |
Miscellaneous | |
Features | 92% light transmittance, front IP65 protection |
Cables Included | 1 x HDMI cable , 1 x USB cable |
Mounting Kit | Included |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 27 kWh/1000h |
Power Consumption (Typical) | 43 Watt |
Power Consumption Stand by | 0.7 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight (Shipping) | |
Shipping Width | 89 cm |
Shipping Depth | 15.5 cm |
Shipping Height | 63 cm |
Shipping Weight | 12.85 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
