Stylish ultra-flat front design and 4K resolution make the ProLite XUB2792UHSU a perfect addition to the desk of any graphic designer. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the 4K (3840 x 2160) resolution means the XUB2792UHSU can accommodate 4 times more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences.
Product Description | iiyama ProLite XUB2792UHSU-B1 - LED monitor - 4K - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 49 kWh | Power Consumption (On mode) | 33.8 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz, DVI: 30 Hz) | Pixel Pitch | 0.16 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 1.07 billion colours | Colour Gamut | 100% sRGB, 72% NTSC | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 61.4 cm x 23 cm x 39.7 cm | Weight | 6.4 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, PSE Mark, VCCI Class B, CU, VESA DDC 2 B | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Viewable Size | 26.9" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 31 - 90 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | Ultra Slim Design, HDCP, Eco-Mode, 10-bit gamma, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, PBP, i-Style Color, 72% NTSC colour gamut |
Colour | Black |
Weight | 6.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), Edge-to-Edge |
Cables Included | 1 x HDMI cable - 1.5 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.5 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption (Typical) | 35 Watt |
Power Consumption Stand by | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
