We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
ProLite X2481HS - a 24" LED backlit LCD screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 3000:1 Native Contrast Ratio, the Prolite X2481HS provides excellent performance for photographic, design and web-design.
Product Description | iiyama ProLite X2481HS-B1 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class F | Energy Consumption per Year | 37 kWh | Power Consumption (On mode) | 21.3 W | Features | Stereo speakers | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2715 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 54.35 cm x 21.35 cm x 38.9 cm | Weight | 3.7 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, VESA DPMS, ISO 9241-307 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.6" |
Built-in Devices | Stereo speakers |
Panel Type | VA |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 24 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, luminance |
OSD Languages | English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color |
Colour | Black |
Weight | 3.7 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI-D , VGA , HDMI , Audio line-in |
Mechanical | |
Tilt Angle | -4/+21 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 21.3 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows 95/98/ME/2000/XP/Vista/7/8 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
