The Intel NUC kit features a customizable board and chassis that are ready to accept a wide variety of memory, storage, and operating systems. For businesses, students, educators, and DIYers.
Product Description | Intel Next Unit of Computing Kit NUC7i3BNHX1 - mini PC - Core i3 7100U 2.4 GHz - 0 GB - no HDD - with 16GB Intel Optane Memory M.2 module | Type | PC barebone - mini PC | Processor | 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core) | Processor Main Features | Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions | Cache Memory | 3 MB L3 Cache | Cache Per Processor | 3 MB | RAM | 0 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | No HDD | Optical Storage | No optical drive | Card Reader | Yes | Graphics Controller | Intel HD Graphics 620 | Audio Output | 7.1 channel surround | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | Dimensions (WxDxH) | 11.5 cm x 11.1 cm x 5.1 cm | Manufacturer Warranty | Limited warranty - 3 years | Bundled with | 16GB Intel Optane Memory M.2 module |
General | |
Type | PC barebone |
Product Form Factor | Mini PC |
Built-in Devices | Infrared receiver |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100U |
Clock Speed | 2.4 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L3 Cache - 3 MB |
RAM | |
Installed Size | 0 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 2 (empty) |
Features | Dual channel memory architecture |
Hard Drive | |
Type | No HDD |
Storage Controller | |
Type | SATA |
Controller Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1 |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SDXC UHS-I Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 620 |
Video Interfaces | HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | 7.1 channel surround |
Compliant Standards | High Definition Audio |
Networking | |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 0 (free) x internal M.2 2242/2280 |
Slots | 2 (total) / 2 (free) x SO-DIMM 260-pin |
Interfaces | 4 x USB 3.0 - Type A (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort/USB-C 3.1 Gen 2 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | Plug and Play, ICES-003, EN55024, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, KN24, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301 489-1, EN 300 893, CISPR32/EN55032, KN32, AS/NZS 2772.2, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17 |
Power | |
Device Type | Power adapter |
Power Provided | 65 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 11.5 cm |
Depth | 11.1 cm |
Height | 5.1 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
