Jabra BIZ 1500 Duo USB Wideband Headset
£65.67
Delivery:
Standard: 1-3 working days
Key features
  • Great sound, with noise-cancelling microphone and HD Voice to deliver professional sounding calls
  • Robust, entry-level design that is easy to use, with all essential features plus volume control unit and mute for USB version
  • All-day comfort, with foam cushions to keep ears cool and a flexible boom-arm that safely rotates 270 degrees
  • Easy to use right out of the box
  • Easy plug-and-play connectivity using the USB port on your PC
  • Noise-cancelling microphones reduce unwanted background noise and are ideal in crowded and noisy open working environments
  • Recommended Use: Phone, Phone, Leisure, Office
  • Connectivity: Wired
  • Earcover : Binaural
Product codes
chevron icon
chevron icon
Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office.
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
chevron icon
Product Description Jabra BIZ 1500 Duo - headset
Product Type Headset - wired - USB
Recommended Use Phone
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance 150 Ohm
Max Input Power 30 mW
Microphone Boom
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£65.67
