Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office.
Great sound
All-day comfort
Tough Design
Product Description | Jabra BIZ 1500 Duo - headset | Product Type | Headset - wired - USB | Recommended Use | Phone | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW | Impedance | 150 Ohm | Max Input Power | 30 mW | Microphone | Boom | Manufacturer Warranty | 2-year warranty |
General | |
Width | 13.1 cm |
Depth | 5.7 cm |
Height | 16.5 cm |
Weight | 146 g |
Earpad Material | Foam |
Audio Output | |
Frequency Response | 20 - 4500 Hz |
Sensitivity | 115.5 dB/mW |
Microphone | |
Type | Boom |
Sensitivity | -32 dBV/Pascal |
Frequency Response | 1000 - 5000 Hz |
Audio Input Details | Uni-directional - 1000 - 5000 Hz |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Cable | |
Cable Length | 95 cm |
Miscellaneous | |
Cable Details | Headset cable - 95 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
