The BIZ 2400 II offers outstanding sound at both ends of the call for a superior customer experience, a corded professional headset that delivers outstanding sound on both ends of the call. Up to 40% lighter than competing headsets and with a low pressure, super-soft leatherette headband, the Biz 2400 II allows the agent to focus on their customer conversation in unrivalled comfort.
Better conversation
The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The ultra-noise-cancelling microphone provides the highest degree of background noise elimination in any of our headsets.
Product Description | Jabra BIZ 2400 II QD Duo UNC - headset | Product Type | Headset - wired - Quick Disconnect | Recommended Use | Phone - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 120 - 4500 Hz | Max Input Power | 20 mW | Microphone | Boom | Microphone Noise Cancelling | Yes |
General | |
Width | 2.7 cm |
Depth | 13.3 cm |
Height | 16.9 cm |
Earpad Material | Leatherette, foam |
Protection | Breath-resistant |
Audio Output | |
Frequency Response | 120 - 4500 Hz |
Diaphragm | 30 mm |
Adjustable Headband | Yes |
Features | PeakStop technology, FreeSpin technology |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Connections | |
Connector Type | Headset (Quick Disconnect) |
Cable | |
Cable Length | 1 m |
Miscellaneous | |
Cable Details | Headset cable - Kevlar reinforced - 1 m |
Compliant Standards | G616 |
