Engage 75 Mono/Stereo
DECT wireless headset with 150 m/490 ft range, up to 13 hours of battery life and integrated busy-light. Can connect to up to five devices simultaneously. Connects to desk phone, softphone, analogue phone, and 2 Bluetooth devices. Meets Skype for Business Open Office requirements.
Product Description | Jabra Engage 75 Stereo - headset | Product Type | Headset - DECT / Bluetooth - wireless - NFC | Recommended Use | Portable electronics, computer, conference | Localisation | Australia, Hong Kong, New Zealand, Singapore, United Kingdom | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | DECT / Bluetooth | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 40 - 16000 Hz | Microphone | Boom | Microphone Operation Mode | Uni-directional | Microphone Noise Cancelling | Yes | Microphones Included | 2 | Controls | Mute, volume, answer/end, reject call | Software Certification | Certified for Skype for Business | Manufacturer Warranty | 2-year warranty |
General | |
Dimensions & Weight Details | Base: 9.3 cm x 9 cm x 10.6 cm / 218 g |
Width | 14.1 cm |
Depth | 3.2 cm |
Height | 16.9 cm |
Weight | 90 g |
Max Operating Distance | 150 m |
Audio Output | |
Frequency Response | 40 - 16000 Hz |
Max Sound Pressure | 118 dB |
Diaphragm | 28 mm |
In-Cord Volume Control | Yes |
Simultaneously Connectable Devices Qty | 5 |
Microphone | |
Type | Boom |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | Headset , 2 x base unit (5 pin Micro-USB Type B) , Base unit (RJ-45) , 2 x base unit (RJ-9) |
Miscellaneous | |
Included Accessories | Power adapter, base unit |
Cable Details | USB cable - detachable , Phone cable - detachable |
Power | |
Battery | Headset battery rechargeable |
Run Time (Up To) | 13 hour(s) |
Recharge Time | 90 min |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
