We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Jabra Evolve 40 UC Mono is a professional headset designed to improve concentration and conversations. Premium noise-canceling technology gives you peace to work in the noisy, open office effectively creating a concentration zone around you, so you can stay focused on the job. The speakers are built for style and comfort with leatherette ear cushions, and are specifically designed to reduce office noise. The concentration zone is completed with a busy-light indicator that signals user availability to colleagues.
Let you and not the task decide where you work. The Jabra Evolve 40 comes with a 3.5mm jack stick incorporated into the control unit giving you the freedom to connect your corded headset to a PC, smartphone or tablet. The control unit also supports comfortable and easy access to most used functions, such as volume and mute. You are also able to answer calls and close calls directly at the control unit thereby increasing your overall flexibility, so you can better focus on the conversation. When not on a call or when you are on the go, the microphone boom arm can be seamlessly integrated into the headband - so you can easily turn your office headset into a personal headset.
The Jabra Evolve 40 UC Mono is optimized for Unified Communication, providing instant "Plug & Play" installation for your headset. The headset works perfectly with all leading vendors of Unified Communication systems, so you can focus on the conversation.
Product Description | Jabra Evolve 40 Mono - headset - replacement | Product Type | Headset - replacement - wired | Recommended Use | Portable electronics, conference | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Mono | Microphone | Boom | Controls | Mute, volume, answer/end |
General | |
Product Type | Headset - wired |
Replacement | Yes |
Audio Output | |
Microphone | |
Type | Boom |
Remote Control | |
Connections | |
Connector Type | Headset (mini-phone 3.5 mm 4-pole) |
Miscellaneous | |
Cable Details | Headset cable |
