We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Put on your Evolve2 40 and feel the noise around you instantly fade, as the isolating foam oval ear cushions and pioneering new angled earcup design work to effectively block out your surroundings, giving you outstanding passive noise cancellation. Instant quiet without leaving your desk. That's the new standard.
Product Description | Jabra Evolve2 40 UC Stereo - headset | Product Type | Headset - wired - USB-A | Recommended Use | Portable electronics, computer - communication | Additional Functions | DSP | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Sound Effects | HD Voice | Noise Isolating | Yes | Microphone | Boom | Controls | Volume, mute button, answer/end |
General | |
Earpad Material | Leatherette, memory foam |
Audio Output | |
Diaphragm | 40 mm |
Features | Busy light, Jabra Direct |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Remote Control | |
Tracking | |
Sensors | Motion sensor |
Connections | |
Connector Type | Headset (4 PIN USB Type A) |
Miscellaneous | |
Included Accessories | Carrying bag |
