Whether you're working in the office or on the go, background noise can really disrupt your flow. Put on your Evolve2 65 and feel the noise around you instantly fade, as the isolating foam oval ear cushions and pioneering new angled earcup design work to effectively block out your surroundings, giving you passive noise cancellation like you've never experienced. You could say it's like a portable quiet room for your head.
Product Description | Jabra Evolve2 65 MS Stereo - headset - with charging stand | Product Type | Headset - Bluetooth - wireless - USB-C | Recommended Use | Portable electronics, phone, computer - communication | Additional Functions | DSP | Colour | Black | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Noise Isolating | Yes | Microphone | Boom | Controls | Volume, mute button, answer/end | Software Certification | Certified for Microsoft Teams | Bundled with | Charging stand |
General | |
Weight | 176 g |
Colour | Black |
Earpad Material | Leatherette, memory foam |
Max Operating Distance | 30 m |
Audio Output | |
Bluetooth Profiles | Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Diaphragm | 40 mm |
Simultaneously Connectable Devices Qty | 2 |
Features | Voice control, Busy light, PeakStop technology, Jabra Direct |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Remote Control | |
Connections | |
Connector Type | Headset (24 pin USB-C) |
Cable | |
Detachable Cable | Yes |
Miscellaneous | |
Included Accessories | Carrying case, USB cable, USB dongle |
Cable Details | USB cable - detachable |
Compliant Standards | G616 |
Power | |
Battery | Headset battery rechargeable |
Run Time (Up To) | 24 hour(s) |
Standby Time | 1600 hours |
Recharge Time | 1.5 hour(s) |
