We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
Product Description | Jabra PRO 930 MS - headset | Product Type | Headset - DECT - wireless | Localisation | Hong Kong, Singapore, United Kingdom | Headphones Form Factor | On-ear monaural | Connectivity Technology | Wireless | Wireless Technology | DECT | Sound Output Mode | Mono | Microphone | Boom | Controls | Mute, volume, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Weight | 27 g |
Max Operating Distance | 120 m |
Audio Output | |
Microphone | |
Type | Boom |
Remote Control | |
Wireless Link | |
Transmission Range | 120 m |
Miscellaneous | |
Cable Details | USB cable |
Compliant Standards | Plug and Play, EN 60950, UL 60950, IEC 60950-1 |
Power | |
Battery | Headset battery rechargeable |
Included Qty | 1 |
Run Time (Up To) | 6 hour(s) |
Standby Time | 36 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
