With Jabra PRO 9460 DUO headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, Jabra PRO 9460 DUO is fitted with a flex boom for optimum voice pick-up. Providing sound for both ears, the Jabra PRO 9460 DUO blocks out background noise, making it possible to handle calls calmly and professionally at all times.
Product Description | Jabra PRO 9460 DUO - headset | Product Type | Headset - wireless - DECT | Recommended Use | PC multimedia, corded phone | Localisation | Hong Kong, Singapore, United Kingdom | Headphones Type | Headphone - binaural | Headphones Form Factor | Convertible | Connectivity Technology | Wireless - DECT | Sound Output Mode | Mono | Frequency Response | 150 - 6800 Hz | Microphone | Boom | Manufacturer Warranty | 2 years warranty |
General | |
Product Type | Headset - DECT |
Weight | 31 g |
Features | Noise cancelling circuit, mute button, answer/end button, volume control, touch sensor operation, built-in DSP, PeakStop Technology, Jabra SafeTone technology |
Headphones | |
Microphone | |
Type | Boom |
Wireless Link | |
Transmission Range | 150 m |
Miscellaneous | |
Cables Included | 1 x USB cable - external , 1 x phone cable - external |
Included Accessories | Neck strap, headband, power adapter, base station, headset charging cradle, earhook |
Compliant Standards | EN 60950, UL 60950, IEC 60950-1 |
Power | |
Battery | Headset battery - rechargeable |
Included Qty | 1 |
Run Time (Up To) | 10 hour(s) |
Standby Time | 46 hours |
Manufacturer Warranty | |
Service & Support | 2 years warranty |
Service & Support Details | Limited warranty - 2 years |
The following resources are available for the Jabra PRO 9460 Duo Dual Connectivity Wireless Headset with Touchscreen
