When you need a headset that sounds great, feels great and looks great - look no further. Jabra Stone3 is simply a real standout among high-end headsets. Because great design goes a long way, the headset's light and curvy design will fit comfortably to the shape of your ear at all times. And when you're on-the-go, put the headset back in its sleek pocket-sized charging stone and it's ready to be taken with you anywhere.
Product Description | Jabra STONE3 - headset | Product Type | Headset - Bluetooth - wireless - NFC | Recommended Use | Portable electronics | Colour | Black | Headphones Form Factor | Over-the-ear mount - monaural | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 3.0 EDR | Sound Output Mode | Mono | Impedance | 16 Ohm | Active Noise Canceling | Yes | Microphone | Built-in | Microphones Included | 2 | Controls | Answer/end | Manufacturer Warranty | 1-year warranty |
General | |
Width | 5 cm |
Depth | 2.5 cm |
Height | 5.8 cm |
Weight | 7 g |
Colour | Black |
Body Material | Polycarbonate, TPE, PC/ABS |
Max Operating Distance | 10 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP) |
Active Noise Cancelling Technology | Noise Blackout |
Diaphragm | 10 mm |
Microphone | |
Audio Input Details | Omni-directional |
Remote Control | |
Wireless Link | |
Transmission Range | 10 m |
Connections | |
Connector Type | USB (5 pin Micro-USB Type B) |
Miscellaneous | |
Included Accessories | 3 gel ear tips |
Cable Details | USB cable |
Power | |
Power Device | Headset charging stand + power adapter - external |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Battery | Headset battery rechargeable |
Run Time (Up To) | 2 hour(s) |
Standby Time | 120 hours |
Recharge Time | 3 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
