Enjoy JBL sound with 300W of power
The 300W of power output ensures great audio performance for your movies and music.
JBL Surround Sound makes movies come alive
Bring movies to life with JBL Surround Sound, without the hassle of any additional wires or speakers.
Rich and deep bass from a 6.5" (165mm) wireless subwoofer
Enjoy rich and deep bass as well as the convenience of flexible placement without the hassle of wires.
Product Description | JBL Bar 2.1 - sound bar system - wireless | Product Type | Sound bar system - 2.1-channel | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 300 Watt | Frequency Response | 40 - 20000 Hz | Interfaces | Bluetooth | Speaker System Details | 1 x sound bar , 1 x subwoofer | Colour | Black-EMEA | Built-in Decoders | Dolby Digital | Sound Effects | JBL Surround Sound |
General | |
Enclosure Colour | Black-EMEA |
Speaker System | |
Audio System Continuous Power (Total) | 300 Watt |
Max Output Level (Max SPL) | 99 dB |
Interfaces | Bluetooth 4.2 |
Recommended Placing | Wall-mountable |
Speaker System Details | |
Speakers Included | 1 x sound bar , 1 x subwoofer - wireless |
Driver Details | Sound bar: 4 x mid-range driver - 2.25" , Sound bar: 2 x tweeter driver - 1.25" |
Driver Details (2nd speaker) | Subwoofer: subwoofer driver - 6.5" |
Connections | |
Connector Type | HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB |
Miscellaneous | |
Included Accessories | Audio cable, remote control, wall mounting kit, batteries, audio (optical) cable |
Compliant Standards | HDCP 1.4 |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 96.5 cm x 6.8 cm x 5.8 cm / 1.9 kg , Subwoofer: 22.5 cm x 22.5 cm x 37 cm / 5.2 kg |
