The JBL Bar 5.1 transforms from a soundbar into a true wireless 5.1 home theater system for an epic movie and music-listening experience. The soundbar features two detachable battery-powered wireless surround speakers with long hours of playtime, total system power, a wireless subwoofer, HDMI inputs to connect 4K devices and Bluetooth. With Dolby Digital, Dolby Pro Logic II and DTS, your movies, music and video games will never sound more incredible. The soundbar features JBL SoundShift, which allows you to instantly switch between the sound from your TV and the Bluetooth sound from your mobile phone or tablet. The soundbar is programmed to respond to your TV remote, so you can control everything with your existing TV remote control. The JBL Bar 5.1 redefines the soundbar experience.
Product Description | JBL Bar 5.1 - sound bar system - for home theatre - wireless | Product Type | Sound bar system - for home theatre - 5.1-channel | System Components | 2 speakers, subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 510 Watt | Frequency Response | 35 - 20000 Hz | Interfaces | Bluetooth | Speaker System Details | 1 x sound bar , 1 x subwoofer , 2 x surround channel speaker | Built-in Decoders | Dolby Pro Logic II, Dolby Digital, DTS decoder | Manufacturer Warranty | 1-year warranty |
General | |
Design Features | Detachable wireless battery-powered rear channel speakers |
Speaker System | |
Audio System Continuous Power (Total) | 510 Watt |
Max Output Level (Max SPL) | 104 dB |
Audio Return Channel (ARC) Capability | Yes |
Interfaces | Bluetooth 4.2 |
Video Pass-Through | 2160 (4K) |
Speaker System Details | |
Speakers Included | 1 x sound bar - wall-mountable , 1 x subwoofer - wireless , 2 x surround channel speaker - wireless |
Driver Details | Sound bar: 6 x mid-range driver - 2.25" , Sound bar: 3 x tweeter driver - 1.25" |
Driver Details (2nd speaker) | Subwoofer: subwoofer driver - 10" |
Connections | |
Connector Type | 3 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB |
Miscellaneous | |
Included Accessories | Audio cable, digital audio cable (optical), remote control, wall mounting kit, HDMI cable, batteries, calibration microphone |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 114.8 cm x 9.3 cm x 5.8 cm / 3.9 kg , Subwoofer: 44 cm x 30.5 cm x 30.5 cm / 13 kg , Surround channel speaker: 16.2 cm x 9.3 cm x 5.9 cm / 600 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
