Charge your iPhone or iPad with the 1 metre ECO Juice Apple Lightning Cable. No need to stick with just White, add some colour to your life.
It is a must have for all of your iPhone & iPad charging needs. The Juice MFI Approved lightning charge and sync cable is compatible with all iPhones, Air Pods & iPads from iPhone 5 & iPad 4's generation onwards, all the way up to the latest iPhone 14.
The Juice ECO Cables are now made from TPE, which produces less carbon to produce than traditional PVC cables.
Product Description | Juice Lightning cable - 1 m | Cable | Lightning cable | Length | 1 m | Colour | White | Connector | Lightning - male | Connector (Second End) | USB - male | Features | Sync and charge |
General | |
Cable Type | Lightning cable |
Length | 1 m |
Colour | White |
Connectivity | |
Connector | Apple Lightning - male |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | MFI |
Dimensions & Weight | |
Weight | 40 g |
