Keep everything you love about your iPadincluding the thin profile and the Apple Smart Cover while adding critical protection for the sides and corners. The Kensington CornerCase Corner & Back Protection quickly and securely snaps onto your iPad to provide the protection you need without adding unnecessary bulk. The most vulnerable parts of your iPad are the corners and the retina display. The Kensington CornerCase has extra thick corners to provide critical corner protection in case you accidentally drop your iPad. And the CornerCase has a raised bezel that helps protect the screen from scratches and other damage as well. Plus with CornerCase means you wont have to worry about getting scratches on the back of your iPad. Ultimately, the best way to prevent damage to your iPad is to avoid dropping it in the first place. The Kensington CornerCase protects your iPad by making it easier to grip and carry, so youre less likely to drop your precious iPad. Just as youd expect from Kensington, the CornerCase is precisely crafted to preserve full access to all ports and both the front and rear cameras. Protect your iPadespecially the vulnerable cornerswith the Kensington CornerCase Corner & Back Protection.
Product Description | Kensington CornerCase for iPad Air - protective case for tablet | Product Type | Protective case for tablet | Colour | Clear transparent | Image Colour Disclaimer | The displayed product image may be a different colour |
General | |
Carrying Case | |
Type | Protective case |
Recommended Use | For tablet |
Features | Corner protection system, camera lens cutout, Smart Cover compatible, port cut-outs |
