The Kensington Duo Gel Mouse Pad with Wrist Support is a soft structure that moulds to the natural curvature of your wrists, providing support and comfort while you work for a better typing experience. Strategically designed with a ventilation channel to help keep your hands and wrists cooler and drier scrolling and clicking for extended periods of time. With a soft finish that is easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer. The rest meets MIL-STD-810H Method 504.3 Contamination by Fluids testing for resistance to breakdown when exposed to cleaning and disinfecting solvents such as alcohol and bleach for at least 24 hours.
Product Description | Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow - TAA Compliant | Product Type | Mouse pad with wrist pillow | Product Material | Vinyl, gel | Dimensions (WxDxH) | 18.2 cm x 24 cm x 2.5 cm | Weight | 420 g | Colour | Black, red | TAA Compliant | Yes | Manufacturer Warranty | 1-year warranty |
General | |
Width | 18.2 cm |
Depth | 24 cm |
Height | 2.5 cm |
Weight | 420 g |
Miscellaneous | |
Features | Ventilation channel, rigid base |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
