Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to maximize your desktop surface area.
Product Description | Kensington Monitor Stand Plus with SmartFit System - monitor stand | Product Type | Monitor stand | Colour | Black | Dimensions (WxDxH) | 30.5 cm x 39.4 cm | Weight | 1.71 kg | Manufacturer Warranty | 2-year warranty |
General | |
Max Load Weight | 36 kg |
Dimensions (WxDxH) | 30.5 cm - 39.4 cm |
Weight | 1.71 kg |
Colour | Black |
Miscellaneous | |
Features | Adjustable height, SmartFit |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
