Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description | Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - Emerald Green | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Emerald Green | Orientation | Right-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Movement Resolution | 1750 dpi | Features | Scrolling wheel, Nano wireless receiver | Battery | 2 x AAA type | Manufacturer Warranty | 2-year warranty |
General | |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Run Time (Up To) | 1 year |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
