Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description | Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Black | Orientation | Right-handed | Dimensions (WxDxH) | 6.6 cm x 10.2 cm x 3.5 cm | Weight | 120 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 6 | Movement Resolution | 1600 dpi | Features | Scrolling wheel | Battery | 2 x AAA type | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.6 cm |
Depth | 10.2 cm |
Height | 3.5 cm |
Weight | 120 g |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Buttons Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Run Time (Up To) | 1 year |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
