Preserve the convenience of one-cable connectivity to your entire desktop setup with the SD3650 Universal USB 3.0 Docking Station from Kensington, a trusted leader in productivity solutions for more than 30 years. What makes the SD3650 unique from the SD3600 is that you can output dual HD video using DisplayPort and HDMI ports, plus we increased the USB 3.0 accessory expansion ports to four, ideal for a flash drive so it can transfer data at 5Gbps. The dock also features Zero Footprint Mounting, so it can be mounted to the back of a VESA-compatible monitor using a Docking Station Mount (sold separately), perfect for desks with limited space.
Product Description | Kensington SD3650 5Gbps USB 3.0 Dual 2K Docking Station DisplayPort & HDMI - Windows - docking station - USB - HDMI, DP - 1GbE | Product Type | Docking station | Docking Interface | USB | Video Interfaces | HDMI, DP | Dimensions (WxDxH) | 19.8 cm x 8 cm x 3.4 cm | Weight | 500 g | Colour | Black | Networking | Gigabit Ethernet | Power | Power adapter DC 5 V | Manufacturer Warranty | 2-year warranty |
General | |
Width | 19.8 cm |
Depth | 8 cm |
Height | 3.4 cm |
Weight | 500 g |
Enclosure Colour | Black |
Networking | |
Data Link Protocol | Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 2 x USB 2.0 - 4 pin USB Type A , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x video - DisplayPort - 20 pin DisplayPort , 1 x network - 1000Base-T - RJ-45 , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x video - HDMI - 19 pin HDMI Type A |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA 100 x 100 mm, VESA 75 x 75 mm |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC, WEEE |
Power | |
Power Device | Power adapter |
Voltage Required | DC 5 V |
System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
