When you need to lift your laptop up to eye level, theres no better ergonomic solution than the SmartFit Laptop Riser. Kensington has been a leader in ergonomics for more than 20 years and the laptop riser features the SmartFit System, which allows you to find your personal height setting for optimal comfort to reduce neck and back strain while you work. It also utilizes Zero Footprint mounting so you can mount a compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
Product Description | Kensington SmartFit Laptop Riser - notebook stand | Product Type | Notebook stand | Colour | Black | Notebook Compatibility | 15.6" | Features | Adjustable height, integrated cable management, anti-skid grip, SmartFit, kensington security slot, Zero Footprint Mounting |
General | |
Colour | Black |
Miscellaneous | |
Weight Limit | 3.49 kg |
