Resting your wrist on a soft, cushioned surface while you click and scroll with your mouse may seem comfortable, but improper positioning can cause discomfort over time. The SmartFit mouse pad not only provides a comfortable gel support, it also allows you to customize and adjust the height of the rest so your wrist is at a neutral angle. An anti-microbial surface resists stains and odors and the non-skid base provides great stability.
Product Description | Kensington SmartFit mouse pad | Product Type | Mouse pad | Colour | Black | Localisation | Europe |
General | |
Colour | Black |
Miscellaneous | |
Features | Adjustable height, antimicrobial finish, integrated gel wrist pad, non-skid backing |
