We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Kingston’s Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing Full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
Product Description | Kingston Canvas Select Plus - flash memory card - 32 GB - SDHC UHS-I | Product Type | Flash memory card | Form Factor | SDHC UHS-I Memory Card | Storage Capacity | 32 GB | Speed Rating | Video Class V10 / UHS-I U1 / Class10 | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Class | Video Class V10 / UHS-I U1 / Class10 |
Read Rate | Up to 100 MB/s |
Features | Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 24 mm |
Depth | 32 mm |
Height | 2.1 mm |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
