We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Deploy mobile workers with confidence
Protecting the sensitive data that employees and contractors work with has evolved from an IT best practice to a business imperative. And once workers go mobile - whether they're working from home, field offices, or while traveling - it becomes even more difficult to keep data secure. That's the IronKey Basic S1000 USB 3.0 hardware-encrypted flash drives. They give your mobile workforce a convenient, high-performing portable storage solution with room for even the largest data sets. And they give you the peace of mind that comes from knowing your data is safe.
Don't let large data files slow you down
Larger data sets mean longer wait times for mobile workers trying to stay productive while on the road. Now with IronKey Basic S1000 USB 3.0 drives, they can stop waiting and start working. This USB 3.0 SuperSpeed drive delivers blazing read performance of up to 400 MB/sec. That's 2x faster than competing USB 3.0 drives and up to 10x faster than USB 2.0 drives.
Enhanced encryption - global compliance
It's tough enough keeping up with data security regulations here in the US - from HIPAA and HITECH to GLBA - but the picture becomes even more complicated internationally. IronKey Basic S1000 helps you nail down this often moving target with a solution that's FIPS 140-2 Level 3 certified. Even better, all IronKey Basic S1000 drives feature hardware-based XTS-AES 256-bit hardware encryption, which provides more protection than CBC and other block cipher modes. And because many regulations are being updated to require this enhanced encryption, IronKey Basic S1000 drives help you future-proof your compliance efforts.
Work with larger data sets
More organizations are making constant use of big data - database files, media content, large documents and more - and that means more storage room. With IronKey Basic S1000 drives, you can store many files and documents.
Rely on IronKey's persistent protection
The IronKey Cryptochip, a proven hardware-based solution, persistently protects your critical data by keeping encryption key management on the device, where it's safe and protected.
Deploy a truly ruggedized solution
IronKey's sleek, anodized aluminum enclosure is built to meet the most stringent standards for military-grade strength and durability. In fact, IronKey Basic S1000 flash drives automatically detect and respond to physical tampering.
Product Description | IronKey Basic S1000 - USB flash drive - 16 GB - TAA Compliant | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 16 GB | Hardware Encryption | Yes | Encryption Algorithm | FIPS 140-2 Level 3, 256-bit AES-XTS | Technology | MLC NAND Flash | OS Required | Linux 2.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 / 10, Apple MacOS X 10.9.x - 10.12.x | TAA Compliant | Yes | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 250 MB/s |
Write Rate | Up to 100 MB/s |
Features | Password protection, shockproof, waterproof, tamper-proof, ruggedized, Cryptochip, dust-resistant |
Miscellaneous | |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 82.3 mm |
Depth | 21.1 mm |
Height | 9.1 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
