Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each system. It's guaranteed to be compatible and backed by legendary Kingston reliability.
Product Description | Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered | Product Type | Memory module | Capacity | 32 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | System specific | Data Integrity Check | ECC | Speed | 2666 MHz (PC4-21300) | Latency Timings | CL19 | Features | Registered | Voltage | 1.2 V | Lead Plating | Gold | OEM Manufacturer Equivalent Part Number | DELL A9781929 | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) | Designed For | Dell PowerEdge C4130, C4140, FC430, FC630, FC830, M630, M830, T430, T630; Precision 5820, 7820, 7920; Precision Tower 5810; Dell EMC PowerEdge C6420, FC640, M640, MX740, MX840, R430, R440, R530, R540, R630, R640, R6415, R730, R740, R7415, R7425, R830, R840, R930, R940, T440, T640, XR2 |
General | |
Capacity | 32 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Module Configuration | 4096 x 72 |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
Compatibility Information | |
Designed For | Dell PowerEdge C4130, C4140, FC430, FC630, FC830, M630, M830, T430, T630 , Dell Precision 5820 Tower, 7820 Tower, 7920 Rack, 7920 Tower , Dell Precision Tower 5810 , Dell EMC PowerEdge C6420, FC640, M640, MX740c, MX840c, R430, R440, R530, R540, R630, R640, R6415, R730, R730xd, R740, R740xd, R740xd2, R7415, R7425, R830, R840, R930, R940, R940XA, T440, T640, XR2 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
