Kingston DataTraveler I G4 - USB 3.0 - 32GB
Key features
  • Large, colorful loop easily attaches to key rings
  • Practical cap protects the USB plug and your data
  • Customizable with your logo and/or digital files
Product codes
chevron icon
chevron icon
DataTraveler G4 - USB 3.0 in a colourful design
USB 3.0 performance, backwards compatible with USB 2.0
Colorful loop attaches to key rings
Practical cap to protect USB plug and your data
Kingston's DataTraveler® Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colours make it ideal for everyday use at work, home, school or wherever you need to take your data.
It's backwards compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. DTIG4 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Capacity:
32GB
Dimensions:
55mm x 21mm x 10.1mm
Warranty/support:
5-year warranty, free technical support
Compatible with:
Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows XP, Mac OS X v.10.6+, Linux v.2.6+ (USB 3.0 connectivity requires a USB 3.0 port)
chevron icon
Product Description Kingston DataTraveler G4 - USB flash drive - 32 GB
Product Type USB flash drive
Interface Type USB 3.0
Storage Capacity 32 GB
Enclosure Colour Red
OS Required Microsoft Windows Vista, Linux 2.6 or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
