With powerful processing, a 360-degree hinge that accommodates 4 learning modes, and Pencil Touch technology, Lenovo 300e (2nd Gen) 2-in-1 laptop delivers a premium classroom experience. Factor in durability features like a sealed keyboard, mechanically anchored keys, and drop-resistance, and this convertible is sure to earn the grade.
Product Description | Lenovo 300e (2nd Gen) - 11.6" - Intel Celeron - N4100 - 4 GB RAM - 64 GB eMMC - UK | Product Type | Notebook - flip design | Operating System | Windows 10 Pro National Academic - English | Processor | Intel Celeron N4100 / 1.1 GHz, up to 2.4 GHz / 4 MB Cache | Memory | 4 GB LPDDR4 (provided memory is soldered) | Storage | 64 GB eMMC | Display | 11.6" LED backlight touchscreen 1366 x 768 / HD | Graphics | Intel UHD Graphics 600 | Input Device | Digitizer, digital pen | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0 | Battery | Up to 10 hours | Security | Trusted Platform Module (TPM) Security Chip | Colour | Black | Dimensions (WxDxH) | 29 cm x 20.4 cm x 2.085 cm | Weight | 1.31 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | TCO Certified Notebooks 8 | Specific Absorption Rate (SAR) | 0.6 W/kg (body) , 0.6 W/kg (limb) | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Processor / Chipset | |
CPU | Intel Celeron N4100 / 1.1 GHz |
Max Turbo Speed | 2.4 GHz |
Number of Cores | Quad-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | LPDDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2400 MHz |
Storage | |
Main Storage | 64 GB eMMC - eMMC 5.1 |
Display | |
Type | 11.6" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare, Pencil Touch technology |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 600 |
Camera | Yes - 720p |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3287 |
Input | |
Type | Keyboard, digitizer, touchpad, digital pen |
Keyboard Layout | UK |
Features | Spill-resistant, anti-pry key caps |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Wireless Controller | Intel Wireless-AC 9560 - M.2 Card |
Battery | |
Technology | Lithium Ion |
Capacity | 42 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces | USB 3.0 , USB 3.0 (Always On) , USB-C 3.0 (Power Delivery) , Headphone/microphone combo jack , HDMI |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Colour | Black |
Case Material | Polycarbonate ABS |
Features | Administrator password, power-on password, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | USB-C power adapter, Lenovo Active Pen |
Compliant Standards | RoHS |
SAR Value | 0.6 W/kg (body), 0.6 W/kg (limb) |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.31 kg |
Sustainability Information | |
TCO Certified | TCO Certified Notebooks 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
Get more from your purchase from one of our essential accessories
