Everything about the IdeaPad 320 is designed to simplify your life. It will handle any task with ease, thanks to powerful processing. From the streamlined design to a cleaner desktop interface, you'll enjoy the simplicity that IdeaPad 320 offers.
Product Description | Lenovo IdeaPad 320-14IKB - 14" - Intel Core i3 - 7100U - 4 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i3 (7th Gen) - 7100U / 2.4 GHz / 3 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 128 GB SSD | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet | Battery | 2-cell - up to 5 hours | Colour | Platinum grey | Dimensions (WxDxH) | 33.83 cm x 24.99 cm x 2.27 cm | Weight | 2.1 kg | Localisation | Language: English / region: United Kingdom |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100U / 2.4 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD 2.5" (5 mm) SATA 6Gb/s - SK Hynix |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Resolution | 0.3 Megapixel |
Sound | Stereo speakers, microphone |
Compliant Standards | Dolby Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 3165 - M.2 Card |
Network Interface | Ethernet |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 30 Wh |
Run Time | Up to 5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , USB-C 3.1 Gen 1 , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | Administrator password, hard drive password, power-on password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.1 kg |
Sustainability Information | |
TCO Certified | - |
