The Lenovo Essential Wired Combo keeps things uncomplicated. This durable keyboard and mouse plugs into any USB port with wired reliability you can count on. The tough waterproof membrane can handle accidental spills without risking performance. Enjoy feel-good typing with quiet keys and number pad in a modern space saving layout. An ergonomic full-size mouse offers comfort and support for all-day use. Increase your productivity as you smoothly complete tasks with the 1000dpi high resolution optical sensor.
Product Description | Lenovo Essential Wired Combo - keyboard and mouse set - UK Input Device | Device Type | Keyboard and mouse set | Interface | USB | Connectivity Technology | Wired | Localization and Layout | UK | Hot Keys Function | Mute, play/pause, backward, forward, volume -, volume + | Protection | Spill-resistant | Pointing Device | Mouse - wired - optical | Manufacturer Warranty | 1-year warranty |
General | |
Interface | USB |
Dimensions (WxDxH) / Weight | Keyboard: 42.4 cm x 14.64 cm x 2.02 cm / 570 g , Mouse: 6.32 cm x 11.13 cm x 3.37 cm / 69 g |
Adjustable Height | Yes |
Pointing Device | |
Type | Mouse - wired |
Movement Detection Technology | Optical |
Movement Resolution | 1000 dpi |
Miscellaneous | |
Compliant Standards | UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KCC, EAC, AAA |
Software & System Requirements | |
OS Required | Microsoft Windows XP/ 7 / 8 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% |
