Meet the Ideapad 330S. Thinner & lighter with narrow bezels for broader viewing, it boasts state-of-the-art processing and accelerated graphics performance. Power through any task with ease.
Product Description | Lenovo IdeaPad 330S-14IKB - 14" - Intel Core i3 - 8130U - 8 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit - English | Processor | Intel Core i3 (8th Gen) - 8130U / 2.2 GHz, up to 3.4 GHz / 4 MB Cache | Memory | 8 GB DDR4 (1 x 4 GB + 4 GB (soldered)) | Storage | 128 GB SSD | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | Up to 9 hours | Security | Firmware Trusted Platform Module (TPM 2.0) Security Chip | Colour | Platinum grey | Dimensions (WxDxH) | 32.31 cm x 23.48 cm x 1.895 cm | Weight | 1.67 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Home 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i3 (8th Gen) 8130U / 2.2 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (1 x 4 GB + 4 GB (soldered)) |
Max RAM Supported | 12 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 128 GB SSD M.2 |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - 720p |
Resolution | 1 Megapixel |
Sound | Stereo speakers, dual array microphone |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | M.2 Card |
Battery | |
Technology | Lithium Ion |
Capacity | 52.5 Wh |
Run Time | Up to 9 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Interfaces Details | USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , HDMI , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Lenovo Settings, McAfee LiveSafe (30 days trial), Lenovo ID, Lenovo App Explorer |
Miscellaneous | |
Case Material | Aluminum, polycarbonate ABS |
Features | Administrator password, hard drive password, power-on password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington mini security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.67 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
