This sleek, portable 15.6" laptop pushes gaming performance to a new level. Thermally optimized to run cooler and quieter with a full-sized backlit keyboard, the Lenovo Legion Y540 laptop is primed for those who demand gaming wherever life takes them.
Product Description | Lenovo Legion Y540-15IRH - 15.6" - Intel Core i5 - 9300H - 8 GB RAM - 256 GB SSD + 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit - English | Processor | Intel Core i5 (9th Gen) - 9300H / 2.4 GHz, up to 4.1 GHz / 8 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD - NVMe + 1 TB HDD / 5400 rpm | Display | 15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz | Graphics | NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630 | Video Memory | 6 GB GDDR6 SDRAM | VR Ready | Yes | Gaming | Yes | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | Up to 10 hours | Security | Firmware Trusted Platform Module (TPM 2.0) Security Chip | Colour | Raven black | Dimensions (WxDxH) | 36 cm x 26.7 cm x 2.59 cm | Weight | 2.3 kg | Localisation | Language: English / region: United Kingdom | Specific Absorption Rate (SAR) | 1.104 W/kg (body) , 1.104 W/kg (limb) | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Home 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (9th Gen) 9300H / 2.4 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM370 |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe) |
Secondary Storage | 1 TB HDD SATA 6Gb/s / 5400 rpm |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
V-Sync Rate at Max Res. | 144 Hz |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% |
Features | Anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630 |
VR Ready | Yes |
Gaming | Yes |
Camera | Yes - 720p |
Resolution | 1 Megapixel |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3287 |
Compliant Standards | High Definition Audio, Dolby Atmos |
Audio Features | Output: Harman audio technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-touch touchpad, white LED backlight |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | M.2 Card |
Network Interface | Gigabit Ethernet |
Features | Dual stream (2x2) |
Battery | |
Technology | Lithium Ion |
Capacity | 57 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 230 Watt |
Connections & Expansion | |
Interfaces | USB 3.1 Gen 1 (Always On) , 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort 1.2 Alt Mode) , HDMI , LAN , Mini DisplayPort 1.4 , Headphone/microphone combo jack |
Software | |
Software Included | Microsoft Office (Trial) |
Miscellaneous | |
Case Material | Polycarbonate ABS |
Features | Administrator password, hard drive password, power-on password, LED lighting |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS, Energy-Related Products (ErP) Lot 3 |
SAR Value | 1.104 W/kg (body), 1.104 W/kg (limb) |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
