Extremley powerful, easy to manage, and configurable, the ThinkCentre M710s SFF can be tailored to meet your computing needs, today AND tomorrow. Boasting the latest performance and storage technology, this PC is super fast, responsive, and efficient. As well as being able to empower you and your business, it comes with robust security features to safeguard your critical data and the built-in reliability your organization can count on.
Product Description | Lenovo ThinkCentre M710s - SFF - Core i5 7400 3 GHz - 8 GB - HDD 1 TB - UK | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7400 / 3 GHz (, up to 3.5 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 1 TB - SATA 6Gb/s - 7200 rpm | SSD Cache | 3D Xpoint (Optane) - 16 GB | Optical Storage | DVD-Writer | Card Reader | 7 in 1 | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Lenovo Companion | Colour | Black | Dimensions (WxDxH) | 9.25 cm x 29.05 cm x 34.35 cm | Weight | 6 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7400 |
Clock Speed | 3 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 3 |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | 7 in 1 card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Mouse Name | Lenovo Calliope Mouse |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111GN |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 3165 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 2 (total) / 1 (free) x M.2 Card |
Interfaces | 6 x USB 3.1 Gen 1 (4 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x audio line-out , 1 x parallel |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 85% |
Operating System / Software | |
Software | Lenovo Companion |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 9.25 cm |
Depth | 29.05 cm |
Height | 34.35 cm |
Weight | 6 kg |
