Extremely portable and flexible, the Lenovo Miix 520 is designed to fit every mood. Feeling creative? Grab the Lenovo Active Pen 2 and write or draw directly on screen - even editing 3D objects scanned from your surroundings. Need to simplify your day? Let Cortana help - she can now respond to your commands from 4 meters away. Fancy some downtime? Detach the keyboard and the Miix 520 becomes a 12" multimedia-rich tablet with stunning display and crisp sound. Add powerful Quad-Core processing and LTE, and Miix is your perfect companion for every situation.
Product Description | Lenovo Miix 520-12IKB - 12.2" - Intel Core i3 - 7130U - 4 GB RAM - 128 GB SSD - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i3 (7th Gen) - 7130U / 2.7 GHz / 3 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 128 GB SSD - NVMe | Display | 12.2" LED backlight touchscreen 1920 x 1200 / WUXGA | Graphics | Intel HD Graphics 620 | Input Device | Keyboard, digitizer, touchpad, digital pen | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 2-cell - up to 8 hours | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader | Colour | Iron grey | Dimensions (WxDxH) - tablet | 30 cm x 20.5 cm x 0.99 cm | Weight | 880 g | Localisation | Language: English / region: United Kingdom |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7130U / 2.7 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Smart Cache |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 128 GB SSD M.2 PCIe - NVM Express (NVMe) |
Display | |
Type | 12.2" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1920 x 1200 (WUXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Resolution | 8 Megapixel (rear), 5 Megapixel (front) |
Camera Features | Rear camera with auto focus |
Sound | Stereo speakers, four microphones |
Compliant Standards | Dolby Audio |
Input | |
Type | Keyboard, digitizer, touchpad, digital pen |
Keyboard Layout | UK |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 39 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | USB 3.0 , USB-C 3.1 Gen 1 (supports DisplayPort 1.2a Alt Mode) , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Included Accessories | Power adapter, keyboard, Lenovo Active Pen 2 |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 880 g |
Dimensions (WxDxH) / Weight Details | 30.39 cm x 21.91 cm x 0.6 cm / 380 g - keyboard dock , 30 cm x 20.5 cm x 0.99 cm / 880 g - tablet |
Sustainability Information | |
TCO Certified | - |
Get more from your purchase from one of our essential accessories
