Powerful enough for the classroom. Rugged enough for the road
The Lenovo N23 is powered by the 6th Gen Intel Braswell processor giving you the performance of a desktop with the mobility of a laptop. The yoga-type design allows you to use it in 4 different modes depending on your activity: Laptop, Tablet, Tent and Stand. The rugged engineering means that dust and spills are not going to be a problem. With up to 8 hours of battery life it is perfect for hard workers.
Key Features
Product Description | Lenovo N23 - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 128 GB SSD - UK | Product Type | Notebook - flip design | Operating System | Win 10 Home 64-bit | Processor | Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache | Memory | 4 GB DDR3L (provided memory is soldered) | Storage | 128 GB SSD | Display | 11.6" LED backlight touchscreen 1366 x 768 / HD | Graphics | Intel HD Graphics 400 | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth, 802.11a/b/g/n/ac | Battery | 3-cell | Dimensions (WxDxH) | 30.05 cm x 21.25 cm x 2.33 cm | Weight | 1.4 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Celeron N3060 / 1.6 GHz |
Max Turbo Speed | 2.48 GHz |
Number of Cores | Dual-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Features | Integrated memory controller, Intel Burst Technology |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Storage | |
Main Storage | 128 GB SSD M.2 |
Display | |
Type | 11.6" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 400 |
Camera | Yes - 720p |
Resolution | 1 Megapixel |
Sound | Stereo speakers, microphone |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | Bluetooth, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 7260 - M.2 Card |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 45 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | 2 x USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington mini security slot |
Included Accessories | Power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.4 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
