Closing the gap between price and performance as well as between entry-level and mainstream workstations. The ThinkStation P410 offers a higher core count and memory capacity than most entry-level workstation.
Product Description | Lenovo ThinkStation P410 - tower - Xeon E5-1630V4 3.7 GHz - 16 GB - SSD 256 GB - UK | Type | Workstation - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon E5-1630V4 / 3.7 GHz (, up to 4 GHz, (Quad-Core) | Cache Memory | 10 MB | Cache Per Processor | 10 MB | RAM | 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-19200 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 - TCG Opal Encryption | Optical Storage | DVD-Writer | Card Reader | 9 in 1 | Graphics Controller | No graphics | Audio Output | Stereo | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 17.5 cm x 42.6 cm x 37.6 cm | Weight | 14 kg | Manufacturer Selling Program | TopSeller | Manufacturer Warranty | Limited warranty - 3 years - on-site - response time: next business day |
General | |
Type | Workstation |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Xeon E5-1630V4 |
Clock Speed | 3.7 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel C612 |
Cache Memory | |
Installed Size | 10 MB |
RAM | |
Installed Size | 16 GB / 128 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Memory Specification Compliance | PC4-19200 |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 2 (empty) |
Features | Registered, quad channel memory architecture |
Configuration Features | 2 x 8 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | TCG Opal Encryption |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 10 |
Optical Storage | |
Type | DVD-Writer |
Card Reader | |
Type | 9 in 1 card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | No graphics |
Audio Output | |
Sound Output Mode | Stereo |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Intel I218-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5" |
Slots | 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - half-length, full-height |
Interfaces | 6 x USB 3.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 2 x USB 2.0 , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in (1 rear) , 1 x audio line-out (1 rear) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, GREENGUARD |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 450 Watt |
80 PLUS Certification | 80 PLUS Platinum |
Efficiency | 92% |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site - response time: next business day |
Dimensions & Weight | |
Width | 17.5 cm |
Depth | 42.6 cm |
Height | 37.6 cm |
Weight | 14 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
