Households in which tablets see heavy multimedia use can opt for the ultra-premium Lenovo Tab P10. Lenovo's tablet redefines the family tablet with a head-turning dual-glass design, all-metal framing and narrow bezels in an ultra-slim and light profile, while its stunning casing gives off a stunning aurora reflection design as you turn it.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Lenovo Tab P10 ZA45 - tablet - Android 9.0 (Pie) - 32 GB - 10.1" - 4G | Product Type | Tablet | Operating System | Android 9.0 (Pie) | Display | 10.1" IPS TFT - LED backlight - 1920 x 1200 - Multi-Touch | Processor | Qualcomm Snapdragon 450 (8-core) | Processor Clock Speed | 1.8 GHz | Storage | 32 GB eMMC | RAM | 3 GB | Supported Flash Memory Cards | microSD | Cellular Technology | 4G | Cellular Protocols | UMTS, FDD LTE, TDD LTE | Wireless Connectivity | 802.11a/b/g/n/ac, Bluetooth 4.2 | Rear Camera | 8 Megapixel | Front Camera | 5 Megapixel | Navigation System | A-GPS/GPS/GLONASS/BeiDou | Radio Tuner Type | FM radio | Security Devices | Fingerprint reader | Battery Run Time | Up to 12 hours | Dimensions (WxDxH) | 16.7 cm x 0.7 cm x 24.2 cm | Weight | 440 g | Colour | Aurora black | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 10.1" IPS TFT - LED backlight |
Resolution | 1920 x 1200 |
Colour Gamut | 70% |
Touchscreen | Multi-Touch |
Image Brightness | 400 cd/m² |
Features | 10-point multi-touch |
Processor | |
Processor | Qualcomm Snapdragon 450 |
Number of Cores | 8-core |
Memory | |
RAM | 3 GB - LPDDR3 SDRAM |
Max Supported Capacity | 256 GB |
Communications | |
Security Protocols & Features | Wi-Fi Direct |
Rear Camera | |
Sensor Resolution | 8 Megapixel |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Navigation System | |
Receiver | A-GPS/GPS/GLONASS/BeiDou |
Multimedia | |
Graphics | Qualcomm ADRENO 506 |
Supported Digital Audio Standards | Dolby Atmos |
Audio | Microphone, four speakers |
Input Device | |
Software | |
Preloaded Software | Clock, Calculator, Contacts, File Manager, Recorder, Launcher, Camera, Skype, Gmail, Google Music, Google Calendar, Netflix, Weather, FM Radio, Google Chrome, Google Docs, Settings, Microsoft Outlook, Notification Center, Google Photo, Google Sheets, ePOS, Out-of-box experience (OOBE), Google Files Go, Google Slides |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD , 1 x Nano-SIM card |
Interfaces | 1 x USB-C/USB 2.0 , 1 x headset mini jack (3.5mm) , 2 x POGO pin |
Battery | |
Technology | Lithium Ion |
Capacity | 7000 mAh |
Standby Time | 336 h |
Run Time Details | Video playback: up to 12 hour(s) , Web browsing: up to 12 hour(s) |
Miscellaneous | |
Case Material | Aluminum, glass |
Sensors | Accelerometer, ambient light sensor, hall sensor |
Vibrating Alert | Yes |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 16.7 cm |
Depth | 0.7 cm |
Height | 24.2 cm |
Weight | 440 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
