A portable entertainment tablet for the value-conscious user. The Tab E7 boasts an enhanced wide viewing screen and a long battery life. And it runs on Android Go so you can enjoy a safe, efficient, and affordable tablet experience.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Lenovo Tab E7 ZA40 - tablet - Android 8.0 (Oreo) - 16 GB - 7" | Product Type | Tablet | Operating System | Android 8.0 (Oreo) | Display | 7" TN TFT - LED backlight - 1024 x 600 - Multi-Touch | Processor | MediaTek MT8167A/D (Quad-Core) | Processor Clock Speed | 1.3 GHz | Storage | 16 GB Embedded Multi-Chip Package | RAM | 1 GB | Supported Flash Memory Cards | microSD | Wireless Connectivity | 802.11b/g/n, Bluetooth 4.0 | Rear Camera | 2 Megapixel | Front Camera | 0.3 Megapixel | Battery Run Time | Up to 5 hours | Dimensions (WxDxH) | 11.054 cm x 1.035 cm x 19.32 cm | Weight | 271.7 g | Colour | Slate black | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 7" TN TFT - LED backlight |
Resolution | 1024 x 600 |
Colour Depth | 16.7 million colours |
Colour Gamut | 50% |
Touchscreen | Multi-Touch |
Image Brightness | 250 cd/m² |
Features | 5-point multi-touch |
Processor | |
Processor | MediaTek MT8167A/D |
Number of Cores | Quad-Core |
Memory | |
RAM | 1 GB - LPDDR3 SDRAM |
Max Supported Capacity | 128 GB |
Communications | |
Rear Camera | |
Sensor Resolution | 2 Megapixel |
Front Camera | |
Sensor Resolution | 0.3 Megapixel |
Multimedia | |
Graphics | IMG PowerVR GE8300 |
Audio | Microphone, speaker |
Software | |
Preloaded Software | Wifi Display |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD |
Interfaces | 1 x Micro-USB , 1 x headset mini jack (3.5mm) |
Battery | |
Technology | Lithium Ion |
Capacity | 2750 mAh |
Standby Time | 250 h |
Miscellaneous | |
Case Material | Plastic |
Sensors | G-sensor |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 11.054 cm |
Depth | 1.035 cm |
Height | 19.32 cm |
Weight | 271.7 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
