The ThinkCentre M625q is the perfect choice for progressive IT managers looking for responsive, secure, space-saving desktops that can be deployed in any office environment. You can install and open apps without delay, find files quickly, and switch between multiple programs seamlessly - all the benefits of a traditional desktop.
Product Description | Lenovo ThinkCentre M625q - tiny - E2 9000e 1.5 GHz - 4 GB - SSD 32 GB - UK | Type | Thin client - tiny | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD E2 9000e / 1.5 GHz (2 GHz) (Dual-Core) | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 8 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 32 GB - SATA 6Gb/s - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R2 | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 IoT Enterprise | Colour | Black | Dimensions (WxDxH) | 17.9 cm x 18.29 cm x 3.45 cm | Weight | 1.3 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - on-site |
General | |
Type | Thin client |
Product Form Factor | Tiny |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | AMD E2 9000e |
Clock Speed | 1.5 GHz |
Max Turbo Speed | 2 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 8 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 1 (Total) / 0 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 32 GB |
Interface Type | SATA 6Gb/s |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R2 |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111HN |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Slots | 2 (total) / 1 (free) x M.2 Card |
Interfaces | 3 x USB 3.1 Gen 1 (2 front, 1 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x serial |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, WEEE, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 88% |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 17.9 cm |
Depth | 18.29 cm |
Height | 3.45 cm |
Weight | 1.3 kg |
