The ThinkCentre M710e small form factor doesn't scrimp on performance. Super compact, this entry-level PC offers robust security features to safeguard your data, powerful performance with high processing, and improved platform stability.
Product Description | Lenovo ThinkCentre M710e - SFF - Core i5 7400 3 GHz - 8 GB - HDD 1 TB - UK | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7400 / 3 GHz (, up to 3.5 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD-Writer | Card Reader | 7 in 1 | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Colour | Black | Dimensions (WxDxH) | 10 cm x 30.35 cm x 27.35 cm | Weight | 4.25 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7400 |
Clock Speed | 3 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 2 |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | 7 in 1 card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Max Monitors Supported | 2 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Mouse Name | Lenovo Calliope Mouse |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111HN |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x M.2 Card |
Interfaces | 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x microphone , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-out |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, WEEE, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 85% |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 10 cm |
Depth | 30.35 cm |
Height | 27.35 cm |
Weight | 4.25 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 19.5 cm |
Shipping Depth | 39 cm |
Shipping Height | 50 cm |
Shipping Weight | 6.45 kg |
