Fitted with powerful processor, the M715 is smaller than a traditional desktop tower and boasts a footprint so small it can fit neatly on a bookshelf, behind a monitor, or even under a desk. Engineered to work in the tough environments, it can handle anything from minor bumps to extreme temperatures and dusty conditions, so you can focus on growing your business and getting your work.
Product Description | Lenovo ThinkCentre M715q (2nd Gen) - tiny - Ryzen 3 2200GE 3.2 GHz - 8 GB - SSD 256 GB - UK | Type | Personal computer - tiny | Localisation | Language: English / region: United Kingdom | Processor | AMD Ryzen 3 2200GE / 3.2 GHz (3.6 GHz) (Quad-Core) | Cache Memory | 4 MB L2 Cache | Cache Per Processor | 4 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express 3.0 x4 - M.2 - TCG Opal Encryption, NVM Express (NVMe) | Optical Storage | No optical drive | Graphics Controller | AMD Radeon Vega 8 | Audio Output | Stereo | Networking | GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Lenovo Vantage, Linkedin | Colour | Black | Dimensions (WxDxH) | 17.9 cm x 18.29 cm x 3.45 cm | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Tiny |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | AMD Ryzen 3 2200GE |
Clock Speed | 3.2 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | AMD B300 |
Cache Memory | |
Installed Size | L2 Cache - 4 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express 3.0 x4 |
Features | TCG Opal Encryption, NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon Vega 8 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111EPV |
Wireless LAN Supported | Yes |
Wireless NIC | Realtek RTL8821CE |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Features | Wake on LAN (WoL) |
Compliant Standards | DASH 1.1 |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x internal 2.5" |
Slots | 2 (total) / 0 (free) x M.2 Card |
Interfaces | 3 x USB 3.1 Gen 1 (2 front, 1 rear) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x headphones , 1 x HDMI |
Miscellaneous | |
Included Accessories | VESA mounting kit, adapter cage |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch, tool-less chassis access |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Compliant Standards | RoHS, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 88% |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Lenovo Vantage, Linkedin |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 17.9 cm |
Depth | 18.29 cm |
Height | 3.45 cm |
