Built to perform, the M820z is a mainstream AIO that transcends the realm of productivity. You can experience supreme performance while working on intensive tasks. The versatile connectivity options, compact design, robust security, and easy manageability make this AIO an ideal choice in all business environments.
Product Description | Lenovo ThinkCentre M820z AIO - all-in-one - Core i5 9400 2.9 GHz - 8 GB - SSD 256 GB - LED 21.5" - UK | Type | Personal computer - all-in-one | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (9th Gen) 9400 / 2.9 GHz (4.1 GHz) (6-core) | Cache Memory | 9 MB | Cache Per Processor | 9 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe) | Optical Storage | DVD-Writer | Card Reader | 3 in 1 | Monitor | 21.5" - LED - 1920 x 1080 (Full HD) - 16:9 | Graphics Controller | Intel UHD Graphics 630 | Camera | Yes | Audio Output | Stereo | Networking | GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Colour | Business black | Dimensions (WxDxH) | 49.1 cm x 25.2 cm x 37.7 cm | Weight | 7.65 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | All-in-one - with UltraFlex III Stand |
Built-in Devices | Stereo speakers |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (9th Gen) 9400 |
Clock Speed | 2.9 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B360 |
Cache Memory | |
Installed Size | 9 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | 3 in 1 card reader |
Monitor | |
Monitor Type | LED - IPS |
Diagonal Size | 21.5" |
Native Resolution | 1920 x 1080 (Full HD) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Anti-glare, Low Blue Light Mode, Wide Viewing Angle, borderless |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Speakers Included | 2 x right / left channel |
Camera | |
Camera | Yes |
Resolution | 1080p |
Features | 180° rotating function, built-in 2 microphones, LED indicator |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111G |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Slots | 2 (total) / 0 (free) x M.2 Card |
Interfaces | 4 x USB 3.1 Gen 1 (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones/microphone , 1 x USB 3.1 Gen 2 (Always On) , 1 x USB-C 3.1 Gen 1 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion switch |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | RoHS, GREENGUARD, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3, TUV Rheinland Ultra Low Noise Certification |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 150 Watt |
Efficiency | 90% |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Cyberlink PowerDVD, CyberLink Power2Go, Lenovo Vantage, Linkedin |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 49.1 cm |
Depth | 25.2 cm |
Height | 37.7 cm |
Weight | 7.65 kg |
